baxi solo
19 Sep 2007
Manchester
hi could anyone help me , i keep gettin water in the pressure switch tubes causin boiler to not work any ideas wats causing it , cheers
Water is probably getting through the flue to it somehow.
Post some pics of flue and we may be able to tell you more
Which solo is it?
Either your flue is getting water ingress or the burner pressure isn't set correctly - allowing condensation to build up.
Both of these faults need to be checked out by a GOOD heating engineer.
AL
