Dear all,
I have a severe blockage issue which prevents 2 radiators from working and would like to know how far I should go with the repiping and if it is useful to replace the radiators as well, in your opinion.
System
The system comprises: 8 radiators, one 7 year old Saunier Duval ThemaClassic boiler (patched up last year with a new expansion vessel), and a 20 year old piping system (10mm non-barrier plastic).
History
For many years, the system was working well and was not maintained at all. I did not even know what an inhibitor was! I started having heating issues with some of the radiators recently last year.
I eventually managed to find a competent heating engineer, who manually flushed each of the radiators, replaced all the valves, which solved the issue for most of the radiators but 2 (one of the ground floor, one on the first floor).
According to this heating engineers, this was the worst magnetite sludge case he had ever seen . Trying to flush (not power flush) through the two blocked pipes did not prove successful.
My options
Based on what I read on this forum, there is no circulation so the use of sludge remover chemicals would not be very useful (and could damage the joints). Power flushing on a heavily blocked 10mm plastic pipe is not recommended either.
The only option left seems to repipe the system. On the one hand I would like a long term option, but on the other hand I not want to do unnecessary work, after all the system was working fine for 20 years!!
My question!
In my case, what would you do:
- Partial repiping by bypassing the current blocked sections (and avoid any floor tile removal)?
- Full repiping (with copper in surface and plastic underfloor)?
- Would it be useful to replace the radiators?
- Would it be useful to replace the boiler?
Could the best option be to do: full repiping + keep current boiler (still a few years to live) + keep current radiators (have had valve replaced and have been manually flushed) + add magnet filter + inhibitor once a year?
All comments welcome! Many thanks.
[/b]
System
History
My options
My question!
[/b]
