hi all first time post for me.
system is approx 6 years old and open with a F&E tank.
I am having trouble with 2 rads which I have removed and flushed out - lots of sludge came out, rads seem clear now. System uses 10mm flexi plastic pipes and the flow on the feed pipes to each of these rads is very weak (proved by fitting a hose to valves and draining the system down), almost a dribble (the returns are ok - lots of pressure). Have put in DS40 to try to clear the pipes but suspect that the flow rate is too low to be effective on the feed pipes in question. However the system is clunking and popping and requires bleeding regularly so I think it is being cleared elsewhere.
Have shut down all working rads to force water thro blocked units still no change, only fitted DS40 2 days ago so may need more time to be effective? I have previously run the system with the feeds onto a hosepipe to give it a clear run thro - no change still a dribble.
Thinking of leaving the DS40 in for a week or so and then powerflushing, thought about a mains flush but it seems a bit complicated for DIYer.
If I powerflush from the blocked rads positions is this likely to clear the blockage or am I likely to cause damage or am I wasting my time and should go for new sections of pipe.
thanks for any advice given.
