Is there anyone who can give me some advice on external rendering?
I've recently rendered (overall thickness about 15 mm) 3 external walls (new build concrete block) one of which has blown twice.
The only thing i can think of that caused it to blow the first time was that the unibond dried out before i applied the scratch and subsequently it blew as it stuck to the dried unibond not the wall!!
So i hacked it off (it came away in bigs chunks) wire brushed the wall, soaked it and reapplyed scratch and top coats minus the unibond this time!
I did a 4 : 1 mix with a waterproofing plasticiser (Rendamix) as directed on the instructions. BOTH COATS
However the render has blown again!
What am i doing wrong? I've rendered several times before and this has never happened and besides the other 2 walls are ok!
I used washed sand and maybe added too much rendamix! could either of these things be the cause?
