The text in the report appears to have been lifted from an article in Aeromagazine published by Boeing themselves. http://www.boeing.com/commercial/aeromagazine/aero_16/polar_story.html
Where it says 'probes' it is referring to multiple aircraft types, then specifically for the 777 the wording implies that there is only one probe location.
For the 777-400 it states that there is only one probe location.
For the MD-11 it states that there are two probe locations.
No point in getting too tied up in how many temperature probes there may be on a 777 though. If you read the article it is accepted by Boeing that although generically the 'probes' are located in the coldest area(s), it is still possible for some fuel in the tank to become colder than the measure.
Well there's a first time for everything. On a day when (allegedly) all other aircraft flying through the same area were dropping to lower altitudes to avoid the exceptional cold, what was different about this one?
[/quote]
Interesting that the design of the tanks pushes the very coldest fuel towards the pump inlets, although this would be a good thing until the fuel actually starts to wax....some fuel may be colder than the fuel measured by the probes, such as the fuel that is in contact with the lower wing skin. This creates a temperature gradient in the fuel tank from the wing skin to the location of the probe.
They don't see this as a problem because fuel temperature is conservatively managed with what they consider to be a wide enough margin for safety. Also in the event of temperature system failure they would simply use TAT.As fuel travels to the boost pump inlets, the bottom, cold layer flows through small flapper valves located on solid tank ribs next to the bottom wing skin. These valves are used to control fuel slosh. Thus, the cold fuel tends to flow toward the boost pump inlets.
When the fuel-temperature-sensing system is inoperative, the FUEL TEMP SYS message is displayed. The flight crew then is instructed to use total air temperature (TAT) as an indication of fuel temperature.
...the potential exists for fuel temperatures to approach the freezing point. However, current airplane systems and operating procedures provide confidence that fuel will continue to flow unobstructed to the engines in all plausible cold-weather conditions likely to be experienced on polar routes.
A review of the service history of transport airplane operations worldwide for the past 40 years does not show a single reported incident of restricted fuel flow because of low fuel tank temperatures. This service history affirms that the criteria used to establish the advisory message are adequate and conservative.
[/quote]
