I have a problem with me boiler.
It is reasonably new and work fine when hot water and central heating are operated but the problem seems to be when the Frost Stat is operated.
when I set this to a temperature above the ambient temperature and set the temp on the pipe stat above that then the boiler Pump switches on but the gas does not fire - which means that it stays on for a long old time until i use the central heating/hot water.
It is alright now but come winter I think its going to be a problem.
My questions are
is this solely a fault with the frost stat ?
or
the connections ?
or
could it be the boiler itself ?
As it's under guarantee (the boiler that is) I would appreciate if anyone knows what the process is - as i assume Mr Worcester Bosch would charge a hefty wedge if it is only the frost stat and connections - but not a penny if the boiler, and Mr independent would give a more reasonable price but may not be able to do any guarantee work on the boiler?
My questions are
or
the connections ?
or
