I have a valliant boiler vcw gb 221H, which was working fine until a couple of weeks ago, when i changed the bleeder valves and a couple of thermostats, at the same time we took the oportunity to flush out the system and add a rust inhibitor, anyway since then the central heating has been causing problems, hot water is fine, whenever i switch on the CH 4 of the 5 radiators come on and one remains cold at the same time the boiler runs for about 5 minutes after which it cuts out, the pilot light stays on, I have now shut off the 3 of the 4 working radiators using the thermostatic valves, the radiator which previously did not heat up now works but the problem with the boiler cutting out still remains. at the same time i have noticed that the temperature gauge on the boiler is not working I have spoken to some corgi registered plumbers who have all said that I need to replace the boiler, great expense, I have spoken to people at valiant who have said that there is still life left in the old dog but i need a corgi registered plumber to ring them and they will talk the plumber thru what needs to be done.. has anybody had any similar problems, if so could you please advise
