Renovating a house and just moved in, thinking I'd finished with the plumbing, but there seems to be one remaining glitch.
I've had the existing combi boiler (Wickes combi 2000 - actually a rebranded Halstead Quattro) moved and I've replaced most of the plumbing. Hot water is fine (my wife loves the new shower!), and the radiators are doing fine so far, but when I finally finished the warm water underfloor heating and ran it (alone - the CH was off) for a couple of hours the boiler overheat trip thingy activated. I left it a few minutes and reset but it happened again. Haven't tried the UHF since, but everything else is still working fine.
Have 2 zones (CH and UHF) - separate controller and 2-port valve for each. The UHF is a small area kit made by Myson (mini-manifold with pump and blend-valve) and seemed to be ok (was getting warmer) until the boiler complained.
My guess was that I needed a bypass - the UHF would be demanding more heat than it can use so something has to take the heat away from the boiler. However the boiler manual says it has a built-in bypass.
Any ideas please? Apologies for the fairly lengthy explanation - I hope it's clear enough!
