Boiler pressures dropping - can this be the problem?
Looks like you will have to redo the tails, unusual place to leak if that is the case.
Are you sure it actually comes form where they go into the rad, and not from the valve spindle or the compression joints on the valves?
I'm not sure what the different parts are called! Will probably call someone in to look at it. I really just wanted to know if that was most likely to be the major part (if not all) of the Boiler pressure problem.
Thanks guys for all your help!
I've got more than a clue about you snobby boy. (Fancy him talking to a commoner like wot I am). :rolleyes:
You know all about me. So far you've guessed:
- I rip-off pensioners at 2.5k for 700 quid combi swaps.
- I was bullied at school.
- I am a snob and still a boy
So I'll guess:
- You can't be trusted in the same room as old ladies.
- You were s*d*m*sed at school
- The only expansion & contraction you know is through your ***ole as a result of the above.
Silly isn't it?
