"Tied to earth" is main equipotential bonding, and it is done to incoming service pipes.i'm not sure of the exact term but I was told that all the pipes would have to be tied to earth.
Supplementary equipotential bonding connects together all extraneous-conductive-parts and the earth conductors of circuits in bathrooms and shower rooms etc. If you haven't got plastic pipes, and the CH supplies a radiator in the bathroom then the pipes for that and the radiator need to be connected to the circuit earth(s) with 4mm² cable.Not sure about main or supplementary but the power for the boiler comes from a 'spur' connected to main power supply.
Good idea - particularly with the clamps, as they don't have the required safety labels.I will get new cable and clamps if needed.
Why?Cross bond all under the boiler with standard bonding clamps.
Interesting that that document should say you need to take a main bonding cable from the CH pipes to the MET, and then not show it in the diagram....
..Now there's a thing. If it does, then take a look at that great big metal manifold linking all the pipes together...
that doesn't link them together that is an pipe that you can use to to refill the system with water, it only connets 2 pipes.
