- Joined
- 11 Jan 2004
- Messages
- 42,762
- Reaction score
- 2,641
- Country
Only if the steel pipe is the pipe going round the house, though.It is actually that pipe which should be bonded.
That depends upon one's interpretation of the punctuation of the reg!Only if the steel pipe is the pipe going round the house, though.
I would hope that everyone would agree. Indeed, if there is no electrical continuity through the meter, it is the upstream pipe (if any within the building), and only that pipe, which needs to be bonded.Punctuation or not, I was taught to connect to the metered pipe, as there may be poor continuity from the external pipe through the meter.
Due to this confusion both sides of the meter are bonded in my house.I would hope that everyone would agree. Indeed, if there is no electrical continuity through the meter, it is the upstream pipe (if any within the building), and only that pipe, which needs to be bonded.
However, as you know, because of the punctuation which has been used, the reg can be (and often is) interpreted as saying that, if there is a meter, the bonding must be on the consumer's side of that meter.
Kind Regards, John
Same here, in the case of my water meter (which looks as if it might well not provide electrical continuity) (I don't have a gas meter) ...Due to this confusion both sides of the meter are bonded in my house.
I'm not quite sure what your point is. Are you agreeing with me that (whatever the regs might be thought to say) the only sensible, appropriate and 'safe' place to bond is upstream of the meter, ideally at 'the point of entry' (so that the fitter can't break the pipe between the point of entry and the bond) - or are you saying something different?Well, the meter fitter is supposed to clip a jump lead across any time they break into the pipe, to avoid losing continuity. So if it's bonded down stream only and the meter is insulating, there could be a potential difference across it. The old pme outside tap issue, but with a better earthed incoming pipe to hold on to.
Yep, even though it makes absolutely no sense, that is one way of interpreting the reg (and the way many seem to interpret it) - but, as said, it is all down to interpretation of punctuation - which may or may not have appeared in print 'as intended'.I read the regs as bonding after the meter but before the first tee but I know there are other interpretations.
Equally I say that sometimes there are better ways.Yep, even though it makes absolutely no sense, that is one way of interpreting the reg (and the way many seem to interpret it) - but, as said, it is all down to interpretation of punctuation - which may or may not have appeared in print 'as intended'.
I dare say I will regret saying this but, as far as I am concerned, if/when there is a conflict between what the regs seem to require and what I regard as 'safe', the regs will get ignored!
Kind Regards, John
I remember, decades ago, on one of the first plastic baths I'd ever seen or handled, there was an 'earthing terminal' (clearly marked as such) attached to the underside of the body of the plastic bath!I have seen a plastic underground feed, a brass main stop valve, and entirely internally plumbed with plastic. Oh and an earth clip on the plastic pipe.
No doubt.No doubt it will say something like "need not be bonded", which actually implies a choice, instead of a more appropriate "plastic cannot be electrically bonded, it is plastic".
Not only, per your prediction, does it say "need not be connected...", but the whole of 411.3.1.2 relates (only) to the required bonding of extraneous-c-ps, and if there is an 'insulating section at the point of entry', then there surely would be no extraneous-c-p to bond?411.3.1.2 of 18th ed DPC" said:... Metallic pipes entering the building having an insulating section at their point of entry need not be connected to the protective equipotential bonding.
