Evening All
Got roped in to looking at the wiring in a friends house over the weekend. They have only been in 2 weeks and in that time, the landing light has never worked. After trying the obvious, removed the ceiling rose cover and found the neutrel had be left out and taped up. Most of you probably know whats coming next.....reconnected and whenever the landing light was switched on, both RCDs (17th board) tripped so as expected, i was looking at the dreaded borrowed neutrel which had been disconnected to stop the rcd tripping.
I am a plant and machinery spark so i have put the problem right in the only way i could think of, running a cable to take a neutrel from the downstairs circuit and disconnecting the borrowed one from the last lighting point. All is now working but is this an acceptable way of sorting this problem?
Also just to satify my own questioning, did both RCDs trip due to the fact that the circuit is 2 way and up and down are both fed from seperate RCDs so the fault was detected across both?
Any advice will be greatfully received, sorry for the long post.
ATB
BP
ATB
BP
