Bosch 1201 Intermittent final spin
3 Aug 2008
Wiltshire
9 yr old Bosch 1201 does everything fine except for an intermittent final spin cycle (sometimes it does, sometimes it doesn't), doesn't care if it's regular, econ or woolen cycles. Fill, drain, wash & rinse cycles normal - drum turns no probs, no weird noises. Additional spin cycle settings may or may not work. The drain pump/impeller is not blocked. If I can't get any final spin to work, unplugging the w/m, waiting a bit then plugging it back in seems to fix the problem. My guess is it's a fault with the controller card/assembly but it's £150 for a new one! Would really appreciate any suggestions before I go this route - or maybe even buy a new machine. Many thanks.
You may find it is a pump or brushes problem. Check impeler on pump if it moves side to side and up and down then it may be this if it is not always pumping as appliance does not spin if full of water. Or it may just be the brushes on the motor itself
Sorry for the late reply - thanks for the suggestions. It's not the impeller I'll check out the brushes this weekend!
Okay, I've checked the brushes, they're fine. Anybody have any other suggestions? I could meter the connections/pins if I knew what to look for.
if the brushes are ok, it will be an intermitant pump problem as these can become warn
Check the pressure system. Pressure chamber partially blocked or intermittent operation of the pressure switch.
Thanks gromitsmate & sleepyhead - I put the brushes back in and so far it's washed 4 loads w/o a problem, using different cycles. Go figure, guess I have to wait for it to act up again!
