Bosch Diswasher problem
28 Nov 2007
My dishwasher drained OK at the end of a wash, and the timer reads 0 as expected - but continued to make a noise inside, as if it were still operating. So I switched it off.
The next time I come to use it, it won't fill with water, and the timer does not count down. Does the timer control the input / output of water?
I'm wondering if the timer control is faulty, in which case, would this be fixed by replacing the control unit just behind the buttons?
Th machine is a SG5342GB/17
Bosch hydrosensor 2.3/2.5Kw.
Any help much appreciated.
Tip the machine back and see if any water comes out.If it does you have an internal leak which will need investigating.
THanks - i will try that. I see that quite a few people suggest checking the float mechanism. Would you normally be able to access this without taking the bottom off the machine? I can't see it simply by removing the food filters?
you have to pull the machine out and go round the back.
Only tip the machine backwards, not forwards until you have got all the water out (because of the electrical parts in the door).
Many thanks JohnD and assuhors.
As you suggeted, I tipped the machine back, and out came a few litres of water.
Plumbed it back in, and it works fine once again.
I'm tempted to just wait and hope it doesn't happen again. But JohnD - you suggest there must be an internal leak. Is there any harm in just emptyting it out when necessary?
If it's a slow leak, that might be quite infrequent. I guess you are then depending on that float device activating correctly? If it doesn't, you have a flood on your hands.
thanks again
