BOSCH EXXCEL 1400 EXPRESS WASHING MACHINE
29 Mar 2013
Derby
Hi I have a Bosch exxcel 1400 express washing machine which has started to stick on the wash cycle and does not move on to the rinse cycle.
The display still shows the correct time for whichever particular washing cycle you choose but when you go to check the machine when that time is up it just display 1 min remaining and its still on the wash cycle.
We then have to manually set to the rinse cycle to rinse the washing.
I would presume its the control board as everything else still works perfect.
I hope someone can help.
Many Thanks
Ian
Hi, I have exactly the same problem.
Bosch Classixx 1400 express intermittent fault.
Wash cycle continues for ever counting down the minutes to 1 then staying at 1. If you stop it and put it on "Rinse" it then rinses, drains & spins as normal.
I've checked the water in valves, the element heats up, the pressure valve pipe is clear, the filter is clear, the drain pipe is clear, the pump pumps-out fine in the rinse cycle.
I can only assume it's the controller.
Did you have any luck?
