brake servo seal
20 Dec 2011
Glasgow
Hi a have corsa c,I think my brake servo is leaking water into my driver side,just wondering what's the best seal spray to use,help needed thanks,want to put end to having water in car cheers
I think there is another thread on this and the writer had to take the plate off and reseal. If you want to try clear silicone sealer on the outer edge where the master cylinder plate bolts to the car body (fire screen) It will need to be fry for the silicone to stick. Inner padding holds quite a bit of water so it will take a while to dry out.
//www.diynot.com/forums/viewtopic.php?t=219554
