I purchased a new 2gang switch from B&Q (branded volex) in stainless steel to replace the switches used to control my bathroom lighting. I fitted it to replace an old paint covered MK switch, matching wires to equivalent terminals. All I added was a loop of wire to connect the earth terminal in the back box to the earth terminal in the front plate of the switch.
Whatever I did the new switch would cause the consumer unit to trip. Not sure why. Reinstalled old switch and the lighting worked and the consumer unit is fine. Assumed it was the earth so tried again with the earth wire to front plate disconnected and again the consumer unit tripped. Swapped in the old switch again.
My diagnosis is a faulty new switch - sound about right?
