BS1566 Cylinder sizes
1 Nov 2022
I am replacing an old vented direct hot water cylinder.
Old clyinder measures 900mm high 550mm diameter (including insulation). Can't measure the actual cylinder due to the insulation. Feed tapping is 150mm off floor.
The new cylinder is "Gledhill Replacyl Stainless Steel Vented Cylinder 900mm x 450mm - Direct Connection".
First question: Is the catalogue size of the new cylinder including insulation or without?
If the catalogue dims are excluding the insulation then the cylinders will be very close.
If not, diameters are 100mm off. 50mm between the centre and the side so pipes would need to be adjusted 25mm each.
Second question: I think 25mm adjustment on existing copper pipes is doable without damaging anything, any feedback?
1 without
2 Depends, but it's been a pleasant rarity for me when I've changed a cylinder without any pipework modification.
3 You can guage the depth of foam insulation by pushing a screwdriver in until it meets metal.
And it's unwise to assume that the gate valve on the cylinder feed will shut off the water 100%
The catalogue does not state the height of the cold water feed tapping, just that it is to BS1566. Does anyone know if it is 100mm or 150mm type on these cylinders? (I have seen both heights on cylinders that claim to conform to BS1566)
As far as I can tell the gate on the feed does nothing, just spins and spins. Had to drain everything down to remove old leaky cylinder. Capped off feed pipe now so I can at least fill the kettle and flush the toilet! No chance of a shower till the new cylinder arrives tho.
It is possible to have cylinders made to your exact specification usually a 3 day turn round.
We have done this on a number of occasions the additional cost is normally less than doing extensive pipework modifications.
We use Newark cylinders but that's mainly because we are close enough to collect.
1 without
1 agree
2 agree
3 agree
And I can almost guarantee the gate will pass, get you some rubber bungs and replace the gates
