Hi all,
I am about to begin building a fire pit /bbq in my garden. It will be sunk in to the ground about 50cm with brick coming out of the ground for about 30cms - to make a total pit of 80cm. This is to allow for pit cooking as well as bbq.
I intend to build the pit out of engineering bricks and start the structure on some paving slabs. The slabs will cover the base of the pit with a gap in them to allow for drainage (although it will normally covered).
I want to have adequate drainage beneath the pit - so was thinking about 30cm of gravel.
I wanted some advice on whether this structure is likely to be secure? Could I dig my pit, pour in the gravel, lay some paving slabs and then build bricks up the side? I expect it to be about 12 bricks high in total.
I also plan to have about 10cm of gravel around the structure to absorb any ground movements. This will then be turfed over up to where the bricks rise from the ground.
Any comment on this proposal? Do you think it would work? Novice so any advice would be appreciated.
