Some advice please.
I have a length of of 2.5 4core swa which I would like to supply my garage. I will be taking the feed from the non RCD side of an MK Sentry CU via an RCBO.
The route length from C.U to garage C.U is 10 -12 meters. Most of the route will be clipped to a wall. A short run will be buried in ground (possibly ducted).
My question is if I bunch the cores in pairs to give me a single phase 5mm2 supply will the Steel conductors be sufficient to use as an earth conductor? Would it be better to run a serperate 6mm2 earth wire?
