I have a 2 way switch, one in the hall one on the landing which has only just started buzzing when switched off.. it only stops buzzing when the light is on, which means I have to leave the light on.. any ideas?
yes it is either a faulty switch (may be) or loose wire (probably) the buzzing you can here is actually arcing, switching on the light gives it an easier path to flow so it no longer arcs
