It occurred to me the other day that I didn't know how close cables and heating pipes can run as a general rule. I know about the rules in the wiring guidelines about down rating cables in higher ambient temperatures but I'm looking for a rule of thumb guide if possible.
The case that made me consider this is a 10mm cable that will be suppling a secondary consumer unit. At one point it will have to cross, at right angles, a couple of plastic heating pipes in the joist space under a floor. My plan was to ensure the cable ran as low down as possible and the pipes as high up as possible and then also insulate the pipes in that area.
In other areas I was planning to run the cables along one joist and the pipes in the next joist space over. Is that far enough apart?
Thanks for your help.
