Cable behind skirting board - allowed ?
7 May 2015
Nottinghamshire
I'm thinking of running some electrical cable behind some skirting board (running horizontally) - it will be in the gap from floorboards to the plaster
Do I need to fit metal conduit over this ?
Is this allowed ?
Thanks in advance
Cabling running horizontally behind a skirting board is almost certainly not going to be in a "safe zone". So if you want to run the cabling there you will need to install the cabling in a manner that is acceptable for use outside the safe zones. Properly earthed metal conduit is one way to do that, using specialised cable types is another.
