Hello
My kitchen is the only room in my house with a concrete floor, the current ring main cables enter the room from below the floorboards in the bathroom via a large hole at the bottom of the kitchen wall.
The current plan is to run the 6mm cable via the same hole, but the cooker will be located on an adjacent wall, therefore, I would appreciate any advice on the best way to run the cable around the room to the CCU to comply with 'best practise' in the 17th edition regs.
The wall area from hole to cooker will contain kitchen base units, so my first thought was to surface clip the cable horizontally on the the wall 6" from the floor all the the way around until it will be run vertically buried in the wall to the CCU and then buried again to the terminal outlet box. (I don't like this route method, but it is ok or has anyone else got a better solution?)
I am aware of part p and the involvement of local council.
regards
olneys
regards
olneys
