Hello,
I live on the ground floor of a seven-storey block of flats with a communal water system. Hot water comes from boilers & calorifiers in the basement (pumped, I assume), cold water comes from a tank in the roof via an old 2-inch lead downpipe (gravity-fed, I assume). I have always had very good water pressure using a Victorian-style combined bath mixer/hand shower.
I just refurbished my bathroom and had a wall-mounted rigid shower riser, thermostatic valve & 8" inch fixed head installed [similar to http://www.screwfix.com/prods/15359...tional-Thermostatic-Mixer-Shower-Rigid-Kit#]. The shower head is now about 2 metres off the floor. Now, both hot and cold shower pressure is very weak - I gat barely a trickle - even though there is still nice, strong pressure to the sink taps and bath taps.
Does it sound to you like my choice of a rigid riser and a large head was simply expecting too much from the communal water system? Would changing the shower rose help? Can I install a pump just for the shower rather than for all the outlets, since the pressure to all the other areas is fine? In fact, can a shower pump be installed in blocks of flats with communal, sealed water systems?
Any thoughts gratefully received.
