Can I fit P shaped shower bath?
5 May 2010
Essex
Hi all
I want to replace an existing bath with P shaped shower bath. A sloping roof prevents me from using the right angle of the bathroom for the shower end as there is insufficient head room. Can the bath be fitted the other way round with the shower end not in a corner? The long side of the bath would still be fitted flush to the wall.
dont really understand what your asking..do you want the p shape to be at an open end with the shower at the other end?or do you want to flip the bath and build a wall for a shower at the tap end?
I want the P to be at the open end ie. shower at the open end because a sloping ceiling prevents standing up at the wall end.
So, you are saying that there won't be a wall behind the taps? You will need to construct a stud wall that comes out from the existing wall, to go behind the taps. This will have the shower head and screen fixed to it.
Hope I have understood this properly! :confused:
Thanks for your help. I was hoping for an easier solution but obviously not meant to be.
