- Joined
- 17 May 2012
- Messages
- 10,789
- Reaction score
- 852
- Country
I've used everbuild foam for fixing insulation and plasterboard to brick, so happy with this product.
I now need to board a slightly uneven old brick wall for a bathroom. I can't decide whether to use hardiebacker again (which I found a bit of a nightmare in the previous shower room, but got the job done) or go for a waterproof, lightweight tilebacker board, like Wickes' STS Professional Tile Backer Board (can't seem to find Marmox, Jackoboard locally or with sensible delivery rates).
My concern is ensuring the board sticks to the wall evenly, without the foam forcing it out of shape - are these boards too flexible? I once used very thin 10mm insulation with foam and the foam expanded and made them unlevel.
If these boards (STS etc) are not suitable for foam, could I get away with just using the fixings? Or maybe lots of gun adhesive (recommendations?) and then fixing.
Talking of fixings - do you think these will be suitable? Stainless Steel Easy Fix Washers
Or is there a better option?
If this is not really suitable, then maybe I could just use the solid 6mm Hardiebacker boards again - but, if they are not totally level, could I have them skimmed to make level? Or is this a big no?
The wall is probably not as bad as I make it out to be ....
