Can I have advice on this brick & concrete problem pleas
1 Aug 2012
Hertfordshire
Hi all, I'm trying to get the garden in order now we have some hot weather and whist trying to figure out what to do with the fact the storm pipe for all the guttering just empties into the garden via the hole in the wall you should be able to see in one of the pics! Great builders!! Anyway hopefully you can see from the photos what I've unearthed. The wall itself seems to have crumbling bricks which were behind a layer of cement, which also didn't take much to hack off. So is this part easily fixed or not? Also this area links to the ground above which is the photo of the drain. I think this is where the bricks have got damp from? Also the hole in front of drain is something I have uncovered and wanted to know if this is also easily fixed?
Many thanks in advance, if more info is needed please just tell me. Ta
Is this a retaining/built up wall between concreted patio and garden, the screen blocks on top of the capped wall look as if they form a balustrade of sorts. If I'm right the rainwater outlet appears to be quite close in relation to the level of the patio level...pinenot :)
