Hi John (and everybody else),
All things considered, I will spend the money on getting the 10mm cable because although I glean from the answers kindly given that doubling up the 6mm cable wouldn't necessarily be illegal / unsafe to do so (if done properly), the needing to make sure that the 2 cables were both successfully anchored in the relative terminals properly / safely would mean having to in effect buy top of the range fittings (ie spend extra on making sure I had something which could certainly safely take 2 6mm cables rather than those just designed for single 10mm ones)..... what I might save on not having to spend around £20 on 10mm cable might be consumed on having to buy the very best / most expensive switch, shower, etc, etc.... Swings and roundabouts.
The next question is this: I have fitted showers in bathrooms, ring mains in kitchens and consumer units into garages in the past (prior to 2004) - I do understand that fuses protect cables / cables get hot [though I would be the first one to admit that I don't know the mathematical formulae behind it all..... but before the H&S brigade jumps down my throat saying "that's why people like me shouldn't be allowed to change a plug", I would say I don't know why cyanide kills people - I just know that it does so I would avoid ingesting it - it wouldn't stop me from transporting it or storing it in a cupboard while following the advice on the label!!!!] - Can someone explain for me the actual process of telling the council / what that route is likely to cost me (ie doing this myself and having my work checked) - or whether I should just pay an electrician to do something I think as a competenet person I ought to be able to do myself but for the hassle of doing so? If I do the work myself and tell the council, can I use the appliance before they come out to check it or would I have to leave the fuse out. Do I have to tell them before I start, during the time of install or afterwards? If afterwards, how long have I got to tell them before I would be considered to be "offending"?
The ludicrous thing about part P is that I can't extend the ring / add another patress in the kitchen to where Mrs IG11 might want one..... But I could always plug in an extension lead and trail it around the back of the sink not forgeting to make sure that the 2nd extension into the first has the join directly behind the taps !!!!!!! Had this been brought in to say "If you want to trade as a sparky, you need this qualification" I'd be all for it - But I really don't want to sort out the wiring in Mrs Brown's loft @ number 22..... I just want to maintain my own property! Being cynical, I think that this has been done PRIMARILY to stop sparkies making a few quid on the side at weekends and not paying income tax for doing cash in hand jobs - people's safety is only secondary, I'd guess.
Another observation about safety would be the colour of the wiring: RED means D A N G E R.... My wife really did think that brown is the new colour for earth - until she was asked what's the yellow & green one for. As I said in a post above somewhere - the idiot running the freezer in the shed on bell cable is still out there and they will continue to do stuff like this - when is someone going to set a modest course (if that's what is needed) to ask simple competence questions for self certifying work on one's own domestic property - other than connecting the earth to the plumbing at various points with an adequate conductor size, do I really need to know voltage drops & coulombs per second / megajoules / impedance / henrys / farads, yada, yada, yada - rather than making sure that the terminals are clean, dry, well insulated and that the cable is screwed down nice and tight to all connectors???? I would not object to paying £25 to get a certificate for my own domestic work only; I don't want to get fleeced whichever way I go and I am sure that there are loads of other people like me out there too.
Rant over !!!
