Candy CDI1012 dishwasher drain pump runs continuously.
l would be surprised if the anti-flood micro switch had failed because I doubt it has ever operated. Would I not be better just disconnecting or shorting out the switch to test it? If not I have a Fluke multimeter.
Is there anything else on this appliance that could cause this fault code?
Does the code auto-reset or is it something the user has to do?
Test the heater, not much else to check other than cable insulation resistance and that leaves the control panel.
