candy sp120 washing machine
22 Mar 2006
Kent
hi i winder if anyone can help i've got a candy washing machine sp120 i changed the bearings in it a few weeks ago as i've had a bit of experiance with washing machines but now i've got another problem the washing machine wont spin now or fill with water but the drum still rotates as if it has got water in it but it hasnt it's not the motor brushes as i've also changed them not sure if it the pressure switch or not
any help will be great
thanks matt
ok thanks i 've jsut cleaned out the chamber and pipe and reconneted it and it made no differance lol even tried it with out the pip connected to the swich and it still did the same thing so i thought it must be the switch so i disconnect the switch and it still did the same thing so think maybe its the module?
Module shouldnt affect fill to machine-fill is done with valves pressure switch and pump
im not sure then lol i thought it was odd that it still worked as if there was water in when i disconnected the pressure switch any idears on how i can find out wats causing the problem?
