i've got a machine mart tiger 15/55 compressor. its 3HP & uses a 40uf capacitor to prevent a huge load being drawn as it starts up.
the compressor was used for several hours on & off for spraying & cut out. every time i try to start it, it blows the 13a fuse. (the induction motor starts to spin)
I've spoken to there tech support & he says check / replace the capacitor, the most likely fault.
the markings are partly rubbed off so i cannot see much info on the cap, can someone please let me know if they have any experience with this model / similar, also
what would happen if i replaced a cap rated @ 250v for one @ 450v?
what would happen if i replaced a cap rated @ 40uf for one @ 130uf?
what would happen if i replaced a cap rated @ 40uf 250v for one 130uf 450v?
seen quite a few on ebay but dont know if it would be safe to use a higher rated one, or what the effects / consequences would be.
thanks in advance,
thanks in advance,
