I have an existing cat flap in an external wall, it's been there years and I'm now going to seal it up.
Inside; I was going to cut a peice of plaster board and 'dot and dab' in the hole, leaving the plasterboard recessed about 5mm. Then use multifinish to skim over. I was then going to use a devils float to 'feather' the edges of the multifinsh so I can then paint over.
1/. Is the above description the correct approach?
2/. What do I do about the hole on the outside of the wall?
Any help would be appreciated.
