Ceiling Joists & Punch Bag
16 Jul 2006
Wales
hi there, I've recently bought myself a 30kg punch bag.
is it ok to hang this on my ceiling joists? (upstairs)
could the use of the bag damage the joists?
help please
btw, a wall bracket won't work as the walls are plasterboard
roof ceiling joists are usually rather small and potentially weak.
you may be better off entering the loft and fixing a batten that spans maybe 3 joists, then fix the punch bag to the batten.
the closer you can fix to the joist end bearing the better.
ok thanks for the help
if I do it that way though, the bag will be too high and if I use extra chain to lengthen it, it will be too swingy if u know what i mean.
this is the plate I will use
can I span the extra timber over 4 joists in the attic, then span another piece over 2 joists in the bedroom ceiling, and then fit this hook centre on to the bedroom timber?
No worries now :)
Got it hanging between the door (on chinup bar).
I figuired door frames are easier to replace than ceiling beams :LOL:
