My central heating system is 15 years old. It's a Worcester oil fired combi boiler doing hot water, about a dozen radiators and a towel rail. It has been serviced every other year and the boiler itself seems OK (although we've had to change a few bits in the last few years). The radiators all have thermostatic valves and there is no room thermostat. Almost all the thermostatic valves are knackered. Some won't shut off and just bake you. Others won't open (or are very reluctant to). I sometimes have to take the thermostatic head off and pull the pin up manually. One radiator is permanently cold. There's a blockage somewhere between a manifold and the inlet valve - I can disconnect it and no water comes out! The piping is a mixture of plastic and copper, all "microbore". Some radiators have slightly colder patches near their bottoms. The piping is mostly between the upstairs floor and downstairs ceiling and having cork tiled the landing, it would be a complete nightmare to try and get to the manifold!
What are my options? I hear there is a boiler scrappage scheme at present. Should we replace the whole system? Would a new oil boiler be that much more efficient than a 15 year old one? (we have no gas). Is there an effective way of flushing it? Could I put an air line on the blocked pipe to try and clear it? Is geothermal heating a viable alternative for a house without underfloor heating?
