We have recently moved into our first house which has a Baxi WM51/3RS conventional boiler.
We have programmed the timer so that the central heating and water comes on at the same time. However only the central heating works, even though the control panel shows that both have switched on.
A friend seems to think that the problem is likely to be an electrical valve in the pipeline somewhere.
To make do, we are having to use the emersion water heater, but this does not heat enough hot water to fill a bath (a must for the wife!).
Our questions to you are
a) can anybody suggested why the hot water may not be working
b) if we get this problem sorted, will this boiler provide us with enough water to fill a bath
c) a completely new combi boiler fitted in the hope that the wife can have a hot bath. BG quoted £3,385 which seems excessive.
We would be really grateful if somebody could point us in the right direction.
Thank you in advance....
____________________________
Moderator
edited title as bbcode does not work in title
Moderator
