I'm planning to tile my kitchen floor and was just wandering if anyone on here has any tips or tricks on how to cut the tiles so they fit neatly around the radiator pipework?
You could use a tile saw readily available from B&Q or similar outlets or better still if you can get hold of a 'rotozip' with the tile cutting bit.
I managed to cut a square out the centre of a tile (to suit a single skt) using a tile saw. I used a durium tipped bit (NOT on hammer action) to get a start to suit the saw blade. Have to make sure the tile is well clampped to 'B&D workmate or whatever
