Hi folks,
I wonder if you can help me? I assume it is NOT normal for a lot of water to keep flowing (spraying) out of the CH pump when the bleed screw is removed (pump not running at the time)? Everything I read says I should expect a trickle, but for me it doesn't stop until the system is completely depressurised.
Does it sound like the pump is knackered?
I'm pretty sure it's not working as it should anyway, it spins, but doesn't seem to be adequately shifting the water away from the boiler.
Thanks in advance,
Will
Thanks in advance,
Will
