chimney construction from blocks?
31 Aug 2009
Essex
Hello.
I have had extension walls built with a chimney and this is how it looks:
My question is, is it ok build from blocks and then use brick slips?
It is not a full chimney, the height will be like this with flue:
Yes it's OK, as the flue is the important bit. But check with the flue manufacturer for how to fill between the flue and chimney
