My push-button toilet cistern (installed about 5 years ago) has stopped filling up properly. Ie - it fills up very slowly.
I'm not very practical, but had a look inside anyway. I could see a thin stream of water coming out of a plastic unit on the left-hand side.
If I turn on the cold-water tap in the bathroom sink, the cistern fills up normally (and quickly). I generally have to wait a few seconds before I do it. (I discovered this by accident.)
When it fills, the thin stream stops and the water level shoots up.
All very odd.
If anyone knows of a simple solution, I'd be very grateful.
I did try opening up a screw-type fitting at the base of the water pipe that leads down to the floor. (This controls water flow.) This had the same effect as turning on the cold water tap. Ie, the cistern filled up again.
The water comes from the mains - not a tank.
Thank you for any help you can give.
Jim
All very odd.
Jim
