My C/H pipework runs in notched out pipework under the floor boards and is not clipped. Originally is was kind of clipped using crossed nails and hessian for protection but I noticed it was wearing a hole in the pipe so removed them. I decided to leave the pipes floating as there seems to be an unusual amount of movement in my house and figured saddle clips would also wear away at the pipes and plastic clips would required deeper notches and due to the movement the pipes would probably pop out of the clips.
There is quite a lot of noise when the pipes heat up the floor boards are coming up for another job I'm reconsidering clipping them. Any recommendations on whether I should clip them and which clips I should use?
