all rads were working fine - except the one in the downstairs extension (ie. rad added later) - lockshield was completely shut. when i opened the valve i could hear water filling the rad - seemed to be totally empty. since then all but two rads have stopped working completely. i've drained the system 2 or 3 times - cleaning in the process, but not much 'crud' was removed - still no improvement. called 2 different plumbers out at seperate times in the end - neither of whom agreed on the same problem. one said the pump was knacked - so i replaced it - same problem - the other said the layout was probably wrong and wanted me to buy a whole new system. i've bled the pump and all rads frequently - but nothing works. i now have only one rad working - the one closest to the heater (backboiler) - in the bedroom above. i've tried to balance the system, initially turning all rads off (lockshields) and turning one on at a time - none except the one that currently works respond and there seems to be no pressure - when i do this with the one that works i can hear water being pushed into the rad quite clearly - help - help - help!!! the only remainig solution i am aware of is powerflushing the system - anybody any ideas?
