- Joined
- 2 Mar 2016
- Messages
- 3
- Reaction score
- 0
- Country
Hi all
I have a triton diverted shower(dove),
It just runs cold, it has worked fine for a good few years. Recently started running cold without getting warm at all. The sink tap still works fine in the same bathroom. Both the sink and the shower are fed from the same pipe work, from a combi boiler, and the sink runs hot and cold as it should.
So I have replaced the thermostatic cartridge in the shower with a manufacturers part. However I still have the same issue.
The shower when on doesn't seem to demand the boiler to ignite but the sink in the same bathroom dose, I have checked the water pressure (bar) and all is fine.
If I run the hot tap in the bathroom and run the shower then the shower runs hot due to it receiving the feed from the same pipe as the sink.
So any thoughts as to a solution??
