Hopefully you guys can help me as i'm puzzled. Heres how it goes..
Only happens on the cold water system, which is a direct feed with no storage tanks.
When any cold water appliance (tap, toilet etc) is opened a period of about 5 seconds occurs then a drop in pressure seems to be heard (change in the water noise pitch) followed by a loud hum / hammer which can last from 1 to 10 seconds.
The noise only occurs when the tap is opened and doesnt bang on opening or closing. It doesnt always occur (2 or 3 times a day), seems to be worse when the water isn't used for a long period and doesn't seem to change when the main stop cock is used to reduce pressure.
I dont think it is a loose pipe issue as it is happening at every tap even the sink which is right next to the main inlet (less than 1m of pipe). Could i have air trapped? if so how can i flush it? also under the sink is a black unit which is connected to the mains after the stop cock which has a vent pipe which goes outside. I can manually use the knob on the top of this which vents water out the pipe outside. What is this?
Please help its driving me mad!
