I have been lurking for a while trying to research how to fix my boiler, hopefully without having to call in a plumber.
First what I know:
The boiler is a baxi/potterton Combi 100. It is now 7 years old.
The system consists of 6 column style rads and one towel rad.
No bypass is fitted, the radiator closest to the boiler and the towel rad do not have thermostatic valves fitted, the others do.
I live in an area of soft water.
The installer did not correctly flush the system or add inhibitor, as a result iron oxide has built up in the system over time.
Problem:
System goes to lock out when turning on for the first time in the morning after a little bit of kettling. Once re-set a couple of times the heating will generally stay on without problem; however if hot water is run, the system will lockout after further kettling.
What I have Done:
Cleaned the system (fernox) and flushed it with mains water twice according to the instructions on this site. Added inhibitor on refill. I have double dosed the chemicals as due to the column rads the system seems to have more water in it than normal. Anyway this improved the kettling somewhat but I still have lockout.
These are the Things I am considering:
Keep cleaning the system out with chemicals.
Get a plumber in to Powerflush it.
Replace the pump or pump head.
Install a magnatec device.
Replacing the entire boiler!
As far as plumbing goes I am a novice, but willing... What should I do next?
Cheers,
Viniga
First what I know:
Problem:
What I have Done:
Cheers,
Viniga
