have a sime 90 combi boiler around 9yrs old ,hot water not very warm,but if you put heating on 5mins before running tap then the water is ok unless you run tap flat out which i would suspect is normal due to incoming water temp goes without saying no problem in summer.the hot water control on boiler is full up .many thanks
