I can only generalise on the layout surrounding this problem.
In my daughters house there are 2 combi boilers in the cellar (the house was at one time 2 houses) . these appear to connect to common pipework which then splits via divertor valves to provide Central heating via one divertor and a flow/return system which provides heat to TWO megaflow heaters in the attic (for bathrooms).through another divertor valve.
The flow/return pipework entering the megaflow tanks never seems to get very hot, and we are convinced that this aspect of the megaflow is hardly heating the water, and that the immersion heaters are doing most of the work.
I strongly suspect that the flow & return pipes into each megaflow is reversed, also as these pipes are the highest in the system they are fitted with automatic bleed valves (and one of these was definitely not at the highest point (which resulted in an air lock).
Further these tanks are probably 25 foot above the boilers, could this have any effect..
Balancing the system!!!!! is it possible that because most of the time BOTH heating and hot water heating is being called for, the hot water loop is losing out.
I am coming round to the idea of reconfiguring the pipework/ controls such that one boiler is dedicated to the heating& kitchen hot water, and the other exclusively to heating the megaflow tanks.
any comments, ideas, suggestions would be very welcome
