I have a Potterton Suprima 120 boiler and a Megaflow unvented hot water heater. I have been having problems recently with my hot water not working and boiler locking out (I know the Suprima does have a tendency to lock out but this is much worse than it was ever previously)
Looking at the pipework diagram for a Fully Pumped Sealed System, it shows an Automatic Balancing Valve between the Primary Flow and Return pipes, across the Cylinder.
On my system I have a short section (about 3 inches) of 15mm pipe running between the two 22mm Flow and Return pipes where a plumber told me there should be the Automatic Balancing Valve. I assume this is wrong?
The effect of this seems to be that the hot flow from the boiler is going through this "short cut" and "short circuiting" the Megaflow. I can tell this because the Return line below (towards the Megaflow) the 15mm short cut is cold, but above it (on its way back to the boiler) it is hot. The boiler is then cutting out because the return water is too hot, but the thermostat in the Megaflow is demanding more heat.
I am proposing to get the ABV inserted in the system and then the system power flushed (two plumbers have told me that the system is really clogged) as my theory is that the coil inside the Megaflow is clogged up which is causing the flow to short circuit.
Does this all make sense? Any other suggestions? Thanks for your help.
