Hi
I've just ordered a new combi boiler- nat gas Worcester Bosch CDi40, reasons for choosing this boler were firstly because I believe this model is reliable and due to power will give me loads of hot water, and secondly because I got it cheap through a company scheme (I work for Siemens who have a tie up with Bosch). We recently moved in to a late 50's 3 bed detached house, which we plan to extend later to 4 beds, and there are 5 in our family. The new boiler will be certainly more than adequate from a heating point of view, but I wanted the extra power for the hot water capability which I envisage will become a big need once my 3 daughters get to be teens (hope to be able to run 2 showers simultaneously).
The existing system is ancient gas fire/back boiler with gravity fed HW, I want to rip this all out and use the cylinder cupboard to make bigger bathroom. I will however retain the existing copper pipe runs to rads where possible (have you seen the bloody price of copper now!)
I'm basically a competent DIYer, my dad was a plumber and taught me quite a bit, and I've installed an oil boiler before but am aware of the new regs for gas installations. Nevertheless money is tight therefore I intend to replace rads, fit TRVs and flush the system, hang and flue the boiler , connect up water myself, leaving only the gas connection to Mr Corgi, am I allowed to do this? If so any idea what is a reasonable cost for Corgi in West Midlands (I estimate less than 1/2 day's work to connect the gas + whatever else is needed to commission boiler)
Also I read in the Worcester boiler literature on the web that it is OK to run hot water pipes to individual taps in 10mm pipe, but instinct tells me to steer clear of it, I guess there would be savings in terms of less wasted dead heat in the pipes, and also less time for hot water to arrive at tap, but Im worried about flow rates. Anyone have any real world experience if 10mm really works OK for HW, especially for baths and showers?
Sorry for lots of questions!
Glynn
Glynn
