Combis & Zone valves?
13 Aug 2007
Bournemouth
Hi All
Looking to replace my existing Boiler (Potterton Kingfisher). Just to give some background ~ Chalet Bungalow ~ 4 beds 3 bath (only 1 actual bath the other two electric showers off, the mains.).
Plus CH which needs to be in 2 zones (part of the house needs heating for a lot longer than the rest. The main zone that requires the longer period of heat is 5 rads (approx (guess) 16000 btu’s and the rest is 7 rads.
The main question is that the last guy I had around to look at it said I can’t put in a Combi because it can’t work with zone valves? Is that right?
Thanks in advance
Mike
No problem zoning a combi system!
I suggest you find a competent installer!
You can have as many zones as you want, and if you plan it right, common areas which come on with any zone.
OK So to follow on from that. What’s the consensus regarding weather compensation?
Combi likely to be Vaillant 831/837.
Mike
There might be a way to do it with aforementioned setup, but I am sticking with two progstats connected to two two port valves. At present I have a Vaillant VCW242 with three zones (third zone to cylinder). New 831 will be taking over to power the two zones once system has been cleaned.
Prognosis with weather compensation is you can't use it with a zoned system - assuming you want the Vaillant WC system.
Furthermore, if you want multiple zones because of differing heat loss, WC will not be a sensible upgrade. It needs a system with a uniform heatloss to deliver results.
The Glow Worm Ultracom CXi boilers (owned by Vaillant) can have Weather compensation and zoning.
That is not exactly true, as long as local temperature trimming control is fitted.
Protherm, Heatline and Glowworm are all owned by Vaillant.
They all address parts of the market that Vaillant doesn't. If the customer wants an ecoTEC that's probably because it is distinctly better made.
Or has an image. The Glow Worm has the stainless Gianonni heat exchanger and most other parts are good quality too. The boiler's controls were redesigned (the hydroblock) after Vaillant got their hands on Glow Worm and the boiler renamed the Ultracom. A well made, reliable boiler.
Not being an installer you wouldn't know about the in service problems, then?
You don't need to ripup floorboards to know.
I reiterate, "The boiler's controls were redesigned (the hydroblock) after Vaillant got their hands on Glow Worm and the boiler renamed the Ultracom. A well made, reliable boiler." That clearly indicates I knew of the early problems.
The earlier versions had free updates of some parts, like replacing the plastic hydro blocks to brass.
What can you tell us about the pump bearings then?
Or was that not in the press releases?
I don't know what was in the press releases. What did yours say?
They have changed the pump from a Grundfos to a Wilo.
BTW, I do not have to justify anything to the likes of you.
